**FREE WIRELESS EXTENDERS WITH SELECTED TP-LINK ROUTERS**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi Guys,
We have an amazing deal thanks to the guys at TP-Link who have decided to help you out buy give away a free 750Mbps wireless range extender with selected products.
The RE210 will allow you to avoid any dead spots in your house for no extra cost. So if you are looking at a new router then we have a selection of options below which will help you out.
The RE210 is shipped out from our stock so no delay in receiving your whole order and no need to go on to other websites to claim your product.
FREE PRODUCT DETAILS:
TP-Link AC750 Wi-Fi Range Extender (RE210) @ £32.99 inc VAT
Features
- Boosts your wireless signal, eliminating previously inaccessible areas or “dead zones”
- Supports all 802.11 a/b/g/n/ac standards of Wi-Fi routers and wireless access points
- Wireless AC technology delivers combined dual band speeds of up to 750Mbps
- Gigabit Ethernet port allows the extender to connect to wired devices as a wireless bridge
- Its compact, wall-mounted design allows for easy, flexible deployment
Boost Your Wireless Network
Tired of Wi-Fi “dead zones”? TP-LINK’s range extender connects to your router wirelessly, strengthening and expanding its signal into areas it can’t reach on its own. The device also reduces signal interference to ensure reliable Wi-Fi coverage throughout your home or office.
High Performance External Antennas
Two external antennas boost your Wi-Fi coverage and reliability, helping your devices stay connected anywhere your network reaches.
Next-Generation Wi-Fi with Universal Compatibility
The range extender features the next-generation Wi-Fi standard, 802.11ac. Wireless AC technology lets it run on dual bands at a blazing combined speed of up to 750Mbps, including 433Mbps on its 5GHz channel and 300Mbps on its 2.4GHz channel. Plus, the extender can work with any standard Wi-Fi router or wireless access point.
Gigabit Wired Speed
A gigabit Ethernet port turns the extender into a wireless bridge, letting you connect a wired device like a Blu-ray player, gaming console, DVR, or smart TV to your Wi-Fi network.
High Speed Mode
High Speed mode maximizes performance by combining the bandwidth of both the 5GHz and 2.4GHz channels to create a lightning-fast connection with one band sending data and the other receiving it. This setting is ideal for bandwidth-intensive tasks like streaming HD video and gaming online.
Hardware Specification
- Standards and Protocols: IEEE802.11ac, IEEE 802.11n, IEEE 802.11g, IEEE 802.11b
- Interface: 1 * 10/100/1000M Ethernet Port (RJ45)
- Dimensions (W X D X H): 3.7x 2.1 x 3.0in. (94 x 54 x 75.2mm)
- Power Consumption: About 6.5W
Wireless Specifications
- Frequency: 2.4GHz & 5GHz(11ac)
- Signal Rate: 5GHz:Up to 433Mbps, 2.4GHz:Up to 300Mpbs
- Wireless Modes: Range Extender
- Wireless Security: 64/128-bit WEP, WPA-PSK / WPA2-PSK
Only £32.99 inc VAT.
ORDER NOW
TP-Link AC1900 Wireless Gigabit Access Point (AP500) @ £119.99 inc VAT
Upgrade Your Wi-Fi Network to 11AC
Lightning-Fast AC1900 Dual Band Wi-Fi
Upgrade your home or office network with the latest-generation of dual band 802.11ac access point, which offers combined speeds of up to 1900Mbps and is perfectly suited to serve multiple devices at the same time. The 5GHz band is ideal for Ultra-HD streaming video and online gaming, while the 2.4GHz band is there for all of your everyday Internet needs, like sending email and browsing the Internet.
Superior Wi-Fi Coverage
Three detachable antennas provide superior coverage to eliminate dead zones. The addition of Beamforming Technology helps concentrate Wi-Fi signal strength in the direction of connected devices to deliver a stable connection, even over long distances.
Gigabit-Class Wired Performance
The Ethernet port can provide gigabit-class Internet access or an ultra-fast connection for wired devices such as smart TVs, game consoles, etc.
1 GHz Dual-Core CPU Supports More Devices
The dual core Broadcom processor improves efficiency and performance by dividing tasks between the cores, effectively allowing multiple things to be done simultaneously. This ensures great performance, even when the AP500 is serving numerous devices and performing multiple complex tasks at the same time.
Easy Setup and Use
The AP500’s powerful web interface allows it to be set up and configured in a matter of minutes. The intuitive design makes installation faster and easier than ever and allows users to monitor and personalize settings for a wide range of functions.
Features
- Simultaneous 600Mbps on 2.4GHz and 1300Mbps on 5GHz totals 1900Mbps Wi-Fi speeds, ideal for 4K streaming and online gaming
- 3 dual band detachable antennas provide superior Wi-Fi coverage to eliminate “dead zones”
- Beamforming technology delivers highly targeted and efficient wireless connections
- Gigabit Ethernet port provides gigabit-class Internet access or an ultra-fast connection for wired device
- Dual Core 1GHz processor ensures great performance, even with more devices connected at the same time
- Various operation modes, including AP, Repeater/Bridge, Client, and Multi-SSID, provide flexible solutions to meet the wireless needs in any situation
Hardware Features
- Interfaces: 1 * 10/100/1000Mbps Ethernet Port (RJ45)
- Dimensions (W X D X H): 9.5 X 6.4 X 1.7 in. (242 X 162 X 44mm)
- Antenna: 3 dual band detachable antennas
Wireless Features
- Wireless Standards: IEEE 802.11a/ac, IEEE 802.11b/g/n
- Signal rate: 2.4GHz: Up to 600Mbps, 5GHz: Up to 1300Mbps
- Reception Sensitivity:
2.4GHz:
11g 54M: -76dBm@10% PER
11n HT20 MCS7: -73dBm@10% PER
11n HT40 MCS7: -71dBm@10% PER
5GHz:
11a 6Mbps:-94dBm@10% PER
11a 54Mbps: -75dBm@10% PER
11ac HT20 MCS8: -66dBm@10% PER
11ac HT40 MCS9: -62dBm@10% PER
11ac HT80 MCS9: -59dBm@10% PER
- Wireless Modes: Access Point, Repeater (Range Extender)/Bridge with AP, Client, Multi-SSID
- Wireless Functions: Wireless Statistic, Concurrent Mode boost both 2.4G/5G WiFi band, LED Control, Domain Login Function
- Wireless Security: 64/128-bit WEP, WPA/WPA2, WPA-PSK / WPA2-PSK
Only £119.99 inc VAT.
ORDER NOW
TP-Link Touch P5 AC1900 Touch Screen Wi-Fi Gigabit Router (TOUCH P5) @ £139.99 inc VAT
A Simple, Intuitive Interface
With its clean, user-friendly design, The Touch P5's display interface provides an ideal portal through which to quickly access and manage your network settings. Now you can modify parental controls, add/remove devices from your network, and change guest access privileges with a few taps on your router's display. For added functionality, the touchscreen display can also function as a clock, when not in use.
Lightning-Fast Wi-Fi Technology
The Wireless AC standard establishes a dual band network, allowing you to connect even more devices while still enjoying speeds of up to 1900Mbps. This means that you can enjoy Ultra High Definition 4K streaming video and lag-free online gaming on the 5GHz band, all while shopping, sending email, and browsing your favorite sites on the 2.4GHz band.
- 5GHz 1300Mbps Wi-Fi
- 2.4GHz 600Mbps Wi-Fi
Superior Wi-Fi Coverage for Your Home
Three external antennas with high-powered amplifiers greatly increase the Touch P5’s range and signal stability. Beamforming technology further improves the router’s coverage by helping it locate wireless devices to form stronger, more reliable connections, even with mobile devices moving from room to room.
Exquisite aesthetics, perfect for display in any location
The elegant design of the body gives your technology an aura of natural continuity in any environment. With the Touch P5, you can proudly integrate a gracefully designed router into your personal decor.
KeyFeatures:
- Game and Stream with AC1900 Speed - Stream 4K HD video and game online without lag over dual 2.4GHz and 5GHz bands
- Intuitive Touchscreen Display - Effortlessly set up and manage your network settings
- Superior Coverage - Maximizes Wi-Fi range with three external antennas with high-powered ampliðfiers
- Beamforming - Focuses Wi-Fi towards devices to form stronger connections
- 1GHz Dual-Core Processor - Handles multiple tasks at once without interruption
- Multi-Purpose Design - Serves as a router, repeater, or access point
- Wireless Type: 802.11ac
- Number of LAN Ports: 4
- Port Speed: 10/100/1000Mbps
- USB Port(s): Yes
- WPS Support: No
Only £139.99 inc VAT.
ORDER NOW
TP-Link AC2600 Wireless Dual Band Gigabit Router (Archer C2600) @ £149.99 inc VAT
The next generation of Wireless AC technology, Multi-User MIMO, lets the Archer C2600 serve several mobile devices at the same time for speeds up to 3X faster performance for all devices on the network. Unleash the full power of your high-performance PCs, smart TVs, and consoles by using the router to seamlessly stream 4K HD video and game online across multiple devices at once with MU-MIMO, powered by Qualcomm MU | EFX.
Stream for the Fastest Wi-Fi
The Archer C2600 uses 4-Stream technology to boost its Wi-Fi capability, allowing its 2.4GHz and 5GHz bands to reach industry-leading max speeds of 800Mbps and 1733Mbps respectively. With 2.53Gbps combined Wi-Fi speed.
Powerful Processing
A 1.4GHz dual-core processor can handle the demand of many users accessing your network at the same time, making it possible for everyone in your home to surf, stream, and game at once without slowing down your network.
Four high-performance external antennas and high-powered amplifiers help the Archer C2600 create a strong, far-reaching network for your home. Beamforming technology further improves the router's coverage by helping it locate wireless devices to form stronger, more reliable connections, even with mobile devices moving from room to room.
A Router You Can Show Off
An elegant, minimal design allows the Archer C2600 to blend well with any room decor. Its LEDs can be switched off to prevent distraction at night when placed in bedrooms or common spaces.
Blazing Wired Performance
The Archer C2600's dual USB 3.0 ports run 10x faster than USB 2.0 for data transfer at lightning speed. Connect external drives to the ports and easily share files, photos, music, and video across your network. To help your wired devices achieve peak performance, the router's four Gigabit Ethernet ports operate 10x faster than standard Ethernet.
Easy Setup and Use
Set up the Archer C2600 in minutes thanks to its intuitive web interface and the powerful Tether app. Tether also lets you manage its network settings from any Android or iOS device, including parental controls and Access Control.
Key Features:-
- 4-Stream for the Fastest Wi-Fi Speeds - The Archer C2600 reaches the fastest max speeds available over its 2.4GHz (800Mbps) and 5GHz (1733Mbps) bands
- Run Multiple Devices Simultaneously - The Archer C2600 operates 3x faster by running MU-MIMO to serve multiple devices at once instead of one at a time
- Multi-Task without Slowing Down - A powerful 1.4GHz dual-core processor lets you smoothly surf, stream, and game at the same time
- Maximum Range - 4 dual band detachable high performance antennas provide maximum Omni-directional wireless coverage with beamforming technology
- TP-LINK Tether provides the easiest way to access and manage the router on your iOS and Android devices
Only £149.99 inc VAT.
ORDER NOW
TP-Link Archer AC3200 Wireless Tri-Band Gigabit Router @ £169.99 inc VAT
Main Features:
- Tri-Band technology creates three separate Wi-Fi bands for connecting more devices to your network without a drop in performance
- Combined 3200Mbps Wi-Fi speed over one 2.4GHz (600Mbps) and two 5GHz (1300Mbps each) bands
- Smart Connect helps devices run faster by assigning them to the best available channel to balance network demand
- Six high-performance antennas maximize coverage area and stability
- 1GHz dual-core CPU and three co-processors handle simultaneous connections without interruption
Product Description:
More Wi-Fi for More Devices
- The Archer C3200 uses Tri-Band technology to run three separate Wi-Fi channels at once, creating a network that can connect to more devices without a trade-off in performance.
- 2.4GHz (600Mbps) Shopping online, streaming music, and browsing on laptops,tablets, and smartphones
- 5GHz-1 & 5GHz-2 (1300Mbps each) Gaming online and watching 4K video on consoles, performance PCs, and smart TVs
Seamless Streaming and Gaming
- With the fastest combined Wi-Fi speed of up to 3200Mbps, the Archer C3200 lets you simultaneously game online and stream video in 4K Ultra HD across multiple devices without lag.
Maximum Coverage and Stability
-Six high-performance external antennas greatly increase the Archer C3200’s range and signal stability. Beamforming technology further improves the router’s coverage by helping it locate wireless devices to form stronger, more reliable connections.
Run All Your Devices At Once
-A powerful 1GHz dual-core CPU and three co-processors easily handle the demand made on the Archer C3200’s network when multiple users are browsing, streaming, and gaming all at the same time.
Lightning-Fast Wired Performance
- External hard drives can connect directly to the Archer C3200 via its USB 3.0 and 2.0 ports, making it easy to share files, photos, music, and video across your network.
Easy Setup and Use
- Set up the Archer C3200 in minutes thanks to its intuitive web interface and the powerful Tether app. Tether also lets you manage its network settings from any Andriod or IOS device, including parental controls and media sharing.
Specification:
- Interfaces: 4 x10/100/1000Mbps LAN Ports, 1 x 10/100/1000Mbps WAN Port, 1 x USB 3.0 Port + 1 USB 2.0 Port
- Wireless Standards: IEEE 802.11ac/n/a 5GHz, IEEE 802.11b/g/n 2.4GHz
- Frequency: 2.4GHz and 5GHz Band1/Band4
- Wireless Functions: Enable/Disable Wireless Radio, WMM, Wireless Statistics
- Wireless Security: 64/128-bit WEP, WPA/WPA2, WPA-PSK/WPA2-PSK encryption
- Dimensions (W X D X H): 7.9 X 7.9 X 1.5 in. (200 X 200 X 39mm)
- External Power Supply: 12V/5A
Detailed Specification: http://www.tp-link.com/en/products/details/cat-9_Archer-C3200.html#specifications
Only £169.99 inc VAT.
PRE - ORDER NOW
TP-Link Archer VR900 AC 1900 Wireless Dual Band Gigabit VDSL2 Modem Router @ £134.99 inc VAT
The Archer VR900 features superfast broadband speeds of up to 100Mbps and supports VDSL2,as well as backward compatibility with ADSL2+/ADSL2/ADSL.The modem router exploits the full potential of VDSL broadband connections to deliver Wi-Fi speeds of up to 1900Mbps(600Mbps on 2.4 GHz and 1300Mbps on 5GHz). Also, by using two dedicated networks, it reduces wireless signal interference.
Versatile Connectivity
The Archer VR900 is an integrated DSL modem router that works with any kind of Internet connection, including VDSL, VDSL2, ADSL, ADSL2, and ADSL2+.With the Gigabit Ethernet WAN option, the Archer VR900 can also be used with any fiber broadband or cable modem with an Ethernet output.While the DSL and Ethernet WAN inputs provide universal compatibility with any Internet service, both of the USB ports also support 3G/4G dongle connections. This universal router gives you the flexibility to keep your current ISP or change ISPs in the future, without compromis-ing wireless performance.
Better Coverage and a More Stable Connection
Three external antennas help the Archer VR900 provide stable coverage throughout your entire home and property. Advanced Beamforming technology automatically locates wireless devices and forms targeted, highly efficient wireless connections.
High Performance Antennas
The Archer VR900's powerful web interface allows it to be set up and configured in a matter of minutes. The intuitive design allows users to easily monitor and personalize settings for a wide range of functions including guest networks and parental controls.
Main Features:
- Versatile Connectivity - Ethernet WAN and USB ports, the VR900 is fully compatible with - VDSL2/ADSL2+/ADSL2/ADSL standard, fiber/cable access and 3G/4G USB dongles
- Superfast Wi-Fi - 600Mbps on 2.4GHz + 1300Mbps on 5GHz
- Maximum Range - High power amplifiers and 3 dual band detachable antennas provide maximum Omni-directional wireless coverage and reliability
- 1GHz Dual-core Processor - Ensures no interruption while processing multiple wired or wireless tasks simultaneously
- Beamforming Technology - Improves wireless range and performance on both 2.4GHz and 5GHz band
Only £134.99 inc VAT.
ORDER NOW
TP-Link AC2600 Wireless Gigabit VDSL/ADSL Modem Router (Archer VR2600) @ £199.99 inc VAT
Features
- 4-Stream for the Fastest Wi-Fi Speeds – The Archer VR2600 reaches the fastest max speeds available over its 2.4GHz (800Mbps) and 5GHz (1733Mbps) bands
-Versatile Connectivity – With DSL, EWAN, and USB ports, the Archer VR2600 is fully compatible with DSL connections, fiber/cable access and 3G/4G USB dongles
- Run Multiple Devices Simultaneously – The Archer VR2600 operates 3x faster by running MU-MIMO to serve multiple devices at once instead of one at a time
- Multi-Task without Slowing Down – A powerful 1.4GHz dual-core processor lets you smoothly surf, stream, and game at the same time
- Maximum Range – 4 dual band detachable high performance antennas provide maximum Omni-directional wireless coverage with Beamforming Technology
- TP-LINK Tether App – TP-LINK Tether provides the easiest way to access and manage the router on your iOS and Android devices
Groundbreaking MU-MIMO: A Giant Leap in Wireless World
With MU-MIMO technology, the Archer VR2600 is able to serve multiple connected devices simultaneously. It dramatically reduces wait-time for all clients by making better use of the unoccupied wireless capacity. This results Wi-Fi that is up to 3x faster on each device.
Enjoy 4K streaming movies, video chats, and online gaming, all at the same time and without any annoying lag or buffering, thanks to the breakthrough MU-MIMO technology.
Industry-leading Wi-Fi Speed
To achieve industry-leading Wi-Fi speeds on both the 2.4GHz and 5GHz bands, the Archer VR2600 uses astonishing 4-Stream technology to boost its wireless capabilities. The 800Mbps + 1733Mbps dual-band Wi-Fi is capable of performing even the most demanding bandwidth-intensive tasks with ease.
Superfast VDSL Broadband
The latest VDSL2 technology allows the Archer VR2600 to deliver impressive VDSL broadband speeds up to 100mbps, which is almost five times faster than ADSL2+. The Archer VR2600 serves as a DSL modem and wirelss router, combining two devices in one. The integrated DSL ports supports all standard DSL connections, including VDSL2, ADSL2+, ADSL2 and ADSL.
With multiple inputs, the Archer VR2600 provides you with a variety of options when connecting to the Internet. As a backup, both of the two USB ports support 3G/4G dongle connections. Additionally, the WAN port allows the Archer VR2600 to accept connections from cable and fiber modems via Ethernet cable.
Four high-performance external antennas help the Archer VR2600 create a strong, far-reaching network for your home. Beamforming technology further improves the router's coverage by helping it locate wireless devices to form stronger, more reliable connections, even with mobile devices moving from room to room.
Lightning-Fast Wired Connection
The Archer VR2600's dual USB 3.0 ports run 10x faster than USB 2.0 for data transfer at lightning speed. You can connect external drives to the ports and easily share files, photos, music, and video across your network.
To help your wired devices achieve peak performance, the router also equipped with four Gigabit Ethernet ports that can operate 10x faster than standard Ethernet.
Easy Setup and Use
Set up the Archer VR2600 in minutes thanks to its intuitive web interface and the powerful Tether app. Tether also lets you manage its network settings from any Android or iOS device, including Parental Controls and Access Controls.
Hardware Specifications
- Interfaces:
1 x 10/100/1000Mbps RJ45 WAN Port
4 x 10/100/1000Mbps RJ45 LAN Ports
1 x RJ11 Port
2 x USB 3.0 Port
- IEEE Standards: IEEE 802.3, IEEE 802.3u, 802.3ab
- VDSL2 Standards: ITU G.993.2, Up to 17a profile (POTS), ITU-T G.993.5 (G.vector)
- ADSL Standards:
Full-rate ANSI T1.413 Issue 2,
ITU-T G.992.1(G.DMT),
ITU-T G.992.2(G.Lite),
ITU-T G.994.1 (G.hs),
ITU-T G.995.1
- ADSL2 Standards: ITU-T G.992.3 (G.DMT.bis), ITU-T G.992.4 (G.lite.bis)
- ADSL2+ Standards: ITU-T G.992.5
- Dimensions ( W x D x H ): 10.4 x 7.8 x 1.5 in. (263.8 x 197.8x 37.3 mm)
Wireless Features
- Wireless Standards: IEEE 802.11a/n/ac 5GHz, IEEE 802.11b/g/n 2.4GHz
- Signal Rate: 1733Mbps at 5GHz, 800Mbps at 2.4GHz
- Transmit Power: 2.4GHz <20dBm(EIRP), 5GHz <23dBm(EIRP)
- Wireless Functions: Enable/Disable Wireless Radio, WDS Bridge, WMM, Wireless Statistics
- Wireless Security: 64/128-bit WEP, WPA/WPA2, WPA-PSK/WPA-PSK2, encryptions, Wireless MAC Filtering
Software Features
- Quality of Service: ATM QoS, Bandwidth Control
- Security: NAT Firewall, Access Control, IP and MAC Address Binding
- Operating Modes: VDSL/ADSL Modem Router, Wireless Router, 3G/4G Router
- DHCP: Server, Client, DHCP Client List, Address, Reservation, DHCP Relay
- Port Forwarding: Virtual Server, Port Triggering, DMZ, ALG, UPnP
- Dynamic DNS: DynDns, NO-IP
- VPN Pass-Through: PPTP, L2TP, IPSec Passthrough
Only £199.99 inc VAT.
PRE-ORDER NOW
