Hello,
Have sucessfully installed FreeBSD, (gave up with Gentoo) and have a basic question for you guys for the moment.
I've just inserted a USB flashdrive into my laptop which the O/S has detected but it has not returned back to the prompt so I cannot enter any commands...
How do I get the command prompt back? I know I can use a different one by hitting Alt+F2 but I don't wish to do that.
Window currently says:
# umass0: <USB 2.0 Flash Disk, class 0/0, rev 1.10/1.0, addr 2> on uhub0
da0 at umass_sim0 bus 0 target 0 lun 0
da0: <USB 2.0 Flash Disk 4.00> Removable Direct Access SCSI-2 device
da0: 1.000MB/s transfers
da0: 248MB (509439 512 byte sectors: 64H 32S/T 248C)
Thanks
Thanks
