I assume you copied the output of 'uname' and used it in your post,hence the domain name.
Your question is just too relative to answer precisely.However FreeBSD 6.2 (i386) is a fast, stable and superbly engineered OS.It has its own userland tools and each release is designed and engineered, not patched like the linux kernel.
However unlike Linux , BSD is not as much of a commercial venture for most companies and hence is does suffer, notably the lack of up to date flash support from Adobe.
I'm currently running 'current 8.0' after FreeBSD 7.0 releng was branched. A Cracking OS, just expect to put some work into it and remember it wont hold your hand like most modern day operating systems.
