Freehand users?
18 Oct 2002
I'm trying to produce a working drawing of a bridge using freehand but I've hit a problem. I've been mucking around testing things and I noticed that when I printed an object, a box measuring 3 x 3 for example, it measured larger at about 3.5mm.
Looking at the line that you use to manipulate the object is in the middle of the stroked line - see the screenshot:
Obviously the measurment is being taken from the blue line. I want to have the object stroked on the inside (like you can do in photoshop) but trawling the web has drawn a blank, maybe I'm not using the correct terms?
Anyone out there know how I can alter this?
Thanks in advance.
