AmDaMan said:Hi, I got a drill today and already the chuck seems to be stuck.
It's a keyless type one and I can't twist it free to remove the drill bit! Surely this is a common problem and there is a way of doing it?
thanks
locutus12 said:if the tapping doesnt work, get a couple of pairs of mole grips, clamp them down on the opposit bits and twist away![]()
penski said:How'd Chuck unstuck a stuck drill chuck if the drill's chuck's stuck?
*n
Burned_Alive said:If im reading you right, i normally just throw the drill into reverse and hold onto the collar
Real men would use their teeth.ElvisFan said:That's the way. But I hold the collar with a stilson.
penski said:I read that as 'stetson'
*n
*n
