Freemake - Corrupt Input Files
19 Oct 2002
Swindoniantown
Guys,
I downloaded and installed Freemake on recommendation from here for converting/stitching of movie (.avi/.flv) files and converting them to DVD etc...
But every time I try and use the software I get a message saying "Input File is Missing or Corrupt"... :confused:
I've checked the files I'm using, their not Corrupt!, and I've also used other files Just to make sure, but it keeps failing at the first hurdle!!
Is there any setting I've missed?, a better version (I'm on v3.0.2) be it older, but works!!, or is there something else that you guys would recommend that Converts/Stitches Movie/Music files (various formats) and creates DVD/Blu-Ray discs??...
Cheers
Sim :)
