- 22 Aug 2005
- Clydebank
Hi all
specs::
freenas
p4 / 1GB dell optiplex gx620
boots via usb
2x 500 GB IDE onboard conroller setup as softraid1 exported via NFS
dlink 1038 card (iirc)
onboard gig nic
esx
e6550/ 4GB
intel pro gig nic
onboard gig nic
boots via usb
datastore is the exported nfs share above
I've just started on redoing some of my network as my old fileserver was struggling due to various issues.
I'm using this command to gauge speeds:
dd if=/dev/zero of=./testdd bs=1024 count=200000
My setup is a P4 freenas box and e6550 esx 4.1.0 box on a dell 755 (more details below)
The problem is I'm getting only about 1.8 Megabyte/s writes to nfs network mounted filesystems within the debian VM
I get approx 5MB/s when writing to the local vm disk (which is nfs mounted vmfs datastore)
If i mount the same nfs share on the mac I get about 14MB/s
Raw disk speed on the freenas is about 29MB/s
Gigabit network.
If i use openfiler and iscsi will i get better speeds?
How do I configure separate storage and data transfer networks ? i have the datastore mounted under 1 ip, but perform the tests on the other ip. How can i ensure esx is using a particular nic.
specs::
freenas
boots via usb
onboard gig nic
esx
e6550/ 4GB
intel pro gig nic
onboard gig nic
boots via usb
Gigabit network.
