FreeNas - Fall at first hurdle
19 Jan 2003
Bristol, UK
Just built a nice NAS box with an older Shuttle PC and 2 x 500GB drives in hardware RAID1.
I am falling at the first hurdle though. Downloaded FreeNAS 8 Beta.
Boot off of the CD. Select option 1 to install to HDD/USB and then no further options.
Guides suggest I should get further options so that I can partition the HDD off to allow for OS/SWAP/DATA partitions.
Any ideas?
Yep it can see the array and install to it fine.
I just don't get the option to partition the array off. Just goes directly to the full install mode.
Maybe it's the image I downloaded? I'll try the older, stable release.
If that doesn't work why not run something like ubuntu off a live USB and set up the partitions there then install freeNAS into the partition that you've already made.
