FreeNAS help please, extra NICs
26 Nov 2002
Romford
Hi, I need some help with FreeNAS please.
I've added a couple of extra NICs to my freenas box and I want connect clients to them using a crossover cable for iscsi.
client NIC2 = 10.0.1.1 255/255/255/252
freenas NIC2 = 10.0.1.10 255/255/255/252
I get a link, but I cant ping 10.0.1.10 from the client PC. (or do anthing else)
Do I need to enable anything within FreeNAS to get these extra NICs working.
On the freenas shell, when i do a local ping to 10.0.1.10 that also doesnt work, so it looks like the interface is down (yet it says its up)
Be grateful if anyone can help.
You need to work on your subnetting a bit, if you're using a /30 then .1 and .10 aren't in the same subnet, hence it's using your default gateway instead...
EDIT: Basically change them to be .1 and .2 if you want to use that netmask, or just make it a /24 instead.
