Freesat TV with recording
28 Dec 2002
South Coast
Looking for a new TV to replace a failed Sky box in a multi room setup. Essentially I've looked at the Humax 1000 Fresat box for recording, but are there Freesat TVs about that you can plug a USB stick into and use that as the recording storage media?
Cheers
Cheers
There are but they are rather expensive and I wouldn't recommend using the TV as a recorder by adding a USB as since it only has one tuner you would not be able to record and watch another channel at the same time and you would be restricted by the capacity of the USB drive.
You would be better just buying a stand alone recorder.
