Freesync setup with Nvidia 2070 S
10 Aug 2015
I've changed from a Vega 64 to Nvidia 2070 Super OC and had a go at setting up FreeSync/G-Sync
I've read my monitor which is a DELL S2719DGF does support this feature with new RTX cards. I've enabled it via the drivers and monitor but when I put the OSD menu on the monitor displays 155 HZ and the game FPS shows between 90 - 120 FPS
Isn't the monitor supposed to sync with the FPS and change the OSD to match the FPS
Found this video which explains what I'm talking about
https://youtu.be/Imf2NhqXMAw
Hi, Don't stop there explain how you sorted it for future switchers. :)
Well I didnt follow the complete steps in the video ( my bad )
There is a few tick boxes which I didnt apply. Mainly number 3 and the enable for this display. Also tick the option to display the OSD G-SYNC compatiable option, helps to see it working with the G-SYNC demo
I then fired up the new COD and with this option eabled I can see G-SYNC turned on and working
Cheers, At some point I'm sure I'll get to try Nvidia out with my adaptive sync panel as many others will. :)
