** FREESYNC SUPER-WIDE MONITOR AT SUB £300? YES PLEASE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
AMD promised us FREESYNC would have no price premium and they were telling us the truth:
LG 29UM67 29" FREESYNC Gaming Super-Wide Widescreen LED Monitor - Black @ £279.95 inc VAT
AMD FreeSync technology is an innovative monitor technology, based on free and open industry standards, to eliminate the tearing and stuttering that has plagued PC gaming for 30 years,” said Roy Taylor, corporate vice president of ISV/IHV partner group at AMD. “We are pleased that LG Electronics stands with us with truly exciting AMD FreeSync-ready displays like the LG UltraWide Gaming Monitor.”
Specification:-
- AMD FreeSync Technology
- Screen Size Class (diagonal): 29"
- Panel Type: IPS
- Refresh rate: 60Hz
- Aspect Ratio: 21:9
- Resolution: 2560x1080
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 1000:1 (500,000,000:1 DCR)
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Connectivity: 2x HDMI, 1x DisplayPort 1.20a
- Speakers: 2x 7W Stereo
- Warranty: 2yr (On-Site with LG - 0344 847 5454)
Was [£299.99] Inc. VAT
Only £279.95 inc VAT.
ORDER NOW
LG 34UM67 34" FREESYNC Gaming Super-Wide Widescreen LED Monitor - Black @ £429.95 inc VAT
Specification:-
- Screen Size Class (diagonal): 34"
- Panel Type: IPS
- Brightness (typical): 320 cd/m2
- Contrast Ratio(Original): 1000:1 (100,000,000:1 DCR)
- Connectivity: 2x HDMI, 1x DisplayPort 1.20a & 2x ThunderBolt
Only £429.95 inc VAT.
ORDER NOW
Acer Predator XG270HUomidpx 27" FREESYNC TN 144Hz Gaming Widescreen LED Monitor - Black/Red (UM.HG0EE.001) @ £429.95 inc VAT
The first FreeSync monitor available for pre-order, based on a very unique high performance TN panel designed for gaming with a 2560x1440 resolution, 144Hz, 1ms, Zeroframe and FreeSync support.
Features:-
- Crisp 27-inch, 2560 x 1440 visuals combined with fast 144Hz refresh rate, 1ms response time, made smooth by AMD FREESYNC™ technology
Specification:-
- Screen Size: 27" (69cm)
- Resolution: 2560x1440 WQHD
- Panel: TN
- Response Time: 1ms
- Refresh Rate: 144Hz
- Brightness: 350cd/m
- Contrast ratio: 1000:1 (100,000,000:1 DCR)
- Connectivity: 1x DVI-D, 1x HDMI, 1x DisplayPort (Display Cable and USB cables included)
- USB 3.0 Hub
- FreeSync Enabled
- Speakers: 2x2W Stereo
- Warranty: 3yr (On-Site with Acer - 0371 760 1000)
ORDER NOW
BenQ XL2730Z 27" FREESYNC 144Hz Gaming Widescreen LED Monitor - Black/Red @ £499.99 inc VAT
**FREESYNC AMD Drivers are launched 19th March**
From years expertise in the development of professional gaming monitors and every close encounter with legendary gamers around the world, we have learned that what defines a truly victorious gaming monitor, or should you say “the best gaming monitor”, really depends on the performance-driven features that make the critical difference between victory and defeat. Gaming is in the details that matter. This is why our engineers and designers strive to perfect every detail that may ultimately contribute to the triumph of the game.
Fast response time of 1ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display.
BenQ’s new Motion Blur Reduction technology further enhances an ultra-smooth, free-of-blur gaming experience, particularly for action-packed FPS games where every millisecond count. With Motion Blur Reduction, gamers no longer suffer from time and gaming comfort lost to poor vision quality created by motion blur and lagging. Instead, they have everything to gain with more reaction time advantage on their side to achieve ultimately a flawless victory.
It is absolutely vital that the XL2730Z give you the flexibility you need to get the color performance you seek. This is why BenQ built into the monitor 20 levels of Color Vibrance setting to meet gamers’ specific viewing requirements and preferences for all types of gameplay. This unique feature is accessible via On Screen Display (OSD) or Display Pilot for added convenience.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your preference and to simulate any in-game experience. Using the Display Mode function, the monitor can be easily changed between 7different screen sizes, from 17”, 19”, 19”W, 21.5W”, 22”W, 23”W, 23.6”W, 24”W and 27”W.
If you’re looking to customize your screen size further, you can also take advantage of the Smart Scaling feature. The Smart Scaling feature gives you the flexibility to freely scale the screen content to any custom size. With just one monitor, you can simulate any game play and practice under different display sizes for tournaments. Use the Display Mode and Smart Scaling together to get the possible view for any application or game.
The newly improved Black eQualizer Dynamic color engine technology takes visibility optimization to a whole new level with automatic brightness adjustments. The XL2730Z is able to detect the input source and automatically fine-tune the amount of brightness enhancement within the range of the brightness level selected by the user. Now, gamers can spot their enemies in critical combat effortlessly and react to any situation quickly without having to lift a finger for manual adjustments.
To ensure that gamers can duplicate the exact same monitor set-up with the highest accuracy, efficiency and convenience, BenQ made a few additions to the XL2730Z’s Adjustment Scale Design. The adjustable height stand is now scaled with 14 height levels trackable by a moving marker. Trackable scales are also added to the screen, which tilts forward and backward to 0°, 10° and 20°, and swivels left and right to a wide range of angles. Every XL2730Z can be your personal XL2730Z.
The S Switch Arc is an external controller that comes with preset buttons that can be customized with personal display settings for gaming, work or entertainment use. The S Switch Arc not only sports a quick key for the Auto Game Mode but also a rounder look for a more natural and comfortable grip that enables gamers to best navigate between game modes.
The newly upgraded Display Pilot function allows users to make all the on-screen display adjustments, plus provides them with direct access to the Game Mode Loader feature for downloading and installing the preset display settings of their favorite game or professional gamer’s screen instantly.
The Auto Game Mode enables the XL2730Z to detect the genre of the game being played and switch the display setting to the corresponding game mode automatically. It is also designed to make new game mode recommendations for download. This unique feature is accessible through the On Screen Display (OSD) setting as well as the Display Pilot software or the S Switch Arc that has a quick key built in for this mode.
To save gamers the hassle of having to re-download and reset game modes, the XL2730Z allows gamers to store game modes onto a USB flash drive for easy and simple carriage. They can also share their own game modes with everyone via cloud storage or social media platforms. This innovative feature allows gaming communities to share, collaborate and bond freely with ease.
Sporting the latest angular, compact base that aligns perfectly parallel to the desk surface and a monitor stand meticulously placed in golden ratio to counter balance the display, the next-generation base stand design offers a new level of stability for the steadiest gameplay – with stringent swivel and shock testing results to prove it. Additionally, the reduced width and depth further shortens the distance between the keyboard and the monitor, bringing you closer than ever to the game.
The aluminum alloy coated monitor stand sends off a sophisticated yet mysterious metallic appeal that conjures up the majesty of the game. On top of that, it is ergonomically optimized with a widened and thickened top handle that’s comfortable to grip, making the monitor much easier to carry from one place to another.
Placing a retractable headphone hook on the left side of the monitor display conveniently puts your headphones within arm’s reach. The material of the headphone hook, which has been upgraded to aluminum alloy, offers extra hardness and strength for improved durability.
Practice long hours with clear, comfortable vision or compete with top-notch vision condition with BenQ’s new Low Blue Light. The blue spectrum light, which is produced by regular computer screens, is a critical cause of eye damage, eyestrain, headaches and sleeping disorders. Now with the offering of various adjustable low blue light levels, gamers can better protect their eyes. So there would be no need for yellow tinted eyeglasses for additional eye protection, and gameplay can be clear, comfortable and hassle-free!
Developed in collaboration with pro gamers, the XL2730Z has been upgraded to eliminate flickering at all brightness levels. This effectively reduces eye fatigue and elevates gaming performance through extreme visual comfort for even the most hardcore gamers enrolling long hours in action. Armed with the Gaming-comfort Flicker-free Technology, the BenQ Gaming Monitor is an epic weapon over your ultimate rivals.
Features:-
Specification:-
- Panel: TN
- Connectivity: 1x Dual Link DVI, 1x HDMI 2.0, 1x HDMI 1.4, 1x DisplayPort 1.20 (Display Cable and USB cables included)
- USB 3.0 Hub
- FreeSync Enabled
- Dimensions (HxWxD mm): 557.4x663.7x226.0
- Weight: 8kg
- Height adjust stand with pivot, swivel and tilt
- Full Specification: http://gaming.benq.com/gaming-monitor/xl2730z/specification/#skip
- Warranty: 2yr
Only £499.99 inc VAT.
ORDER NOW
This is a Pre-Order ONLY deal but you have plenty of time to get your pre-order in as stock us due in approx. 8 weeks time and this is an OcUK exclusive, no competitor in the UK will get stock of this item.
We expect 1000 units, but insane sales as this price is actually below the none FREESYNC version. :)
I wouldn't touch the LG screens as the freesync range only operates from 48-75HZ
That benq is very tempting but I think it should be a £100 cheaper ;)
Samsung looking around May, I shall be phasing them into the webshop in a week or two. :)
Can you please phase them earlier? (Next week ;))
Is there a reason why Samsung is late? These monitors (UE590 23.6" and 28") were supposed to be available from March (according to Sammy's announcement back in 21 Nov 2014). Is the delay related to the AMD driver issues? (delay)
I'd be surprised if AMD manage to get a driver that supports free sync out by May and more importantly whether anyone will still have radeons by that time!
Will be when I get some free time to do it and the delay no idea, but Samsung rarely release anything on time.
Thanks Gibbo. Fingers crossed you'll find at one point some time.
I am really interested in those two Samsung 4K models because if I am correct then those 2 are the only Freesync 4K models (in the near future). Literally there is no info out there.
Why are all 120Hz+ freesync panels TN?
Acer clearly have the 1440p 144hz ips panel, but use it only in the G-sync monitor and go back to TN for freesync.
I gave in and purchased the samsung curved, I don't have the patience to wait any longer for a 1440 ultra wide freesync version with or without 120hz + tone announced and then released 6 months later. If that's the case in 1 years time I'll sell my samsung for the new model.
I'm interested in the 29" LG but have a question.
I've read somewhere that when not using FreeSync, the max frequency is limited to 60hz. Could someone confirm?
I ask this, because I play most of the time under OSX (LoL,D3, SC2, ...).
