Freeview C4 + ITV = B0rked?
Aod
Aod
7 Oct 2004
London
i have no idea, they work on non-digital mode, but in digi-mode they don't.
the signal information window (on the TV) shows the signal strength at 27% (which is normal) but it keeps going to 27% for 1 second, then 0% for a second and back again, ad nauseum.
it it just me?
On the freeview tuner built into my TV their working, signal starts off unwatchable then just goes completely. However, via the external freeview + HDD box, they work fine, which is very strange and quite annoying.
Also having problems was thinking my nebula was playing up, also in london pointing at Crystal Palace
As I just found out (on the nebula forums), ITV/C4/C5 are transmitted in 64QAM, which is inherently more susceptible to interferance/problems. Doesn't account for the analogue disruption though. :)
Dont get them here in Pompey - apprently cos it interfers with French tv transmissions. Oddly enough we get E4+1 but not E4.
If you are using the Rowridge transmitter from the Isle of Wight it carries the full compliment of channels, ITV, C4, E4, everything. If someone has told you something else either you have some interference problem or they're having you on.
How do you find out what transmitter you are using - also guess its not possible to change it either.
Just going by what my lectuer told us in one of our lectures.
I 'think' some digi boxes give the transmitter codes that you're using so you could find out that way. Failing that, it's more than likely the closest one to you.
If you move your aerial you can change it provided their in range. The one we use is about 40 miles from us, however our closest transmitter is around 6 miles, but that doesn't broadcast digital :). Although it means that we get Birmingham news :/
I'll have a try at re-tuning it. Dont think I could reposition the aerial living in halls - as much as I'd like too.
yer, i get all my stuff from Xtal Palace too.
tried re-scanning it, no worky and the aforementioned channels are no-longer on the channel list. :p
strange E4+1 and more4+1 both work fine...
