Freeview issues
15 May 2006
I recently bought a freeview box (digifusion rewind tv) and have set it up in my room but the recieved signal is only at 72, and constantly switches to "the received signal is to corrupt"
I have a booster which moved it to 72 from about 52, but unfortunately channels still flicker and distort. I also have trouble picking up certain channels including C4.
The odd thing is my grandad has freeview in the living room and has no problems whatsoever, and doesn't even have a booster. We're connected to the same aerial, so why would mine not work when his does? I have purchased new leads and wires and it hasn't helped at all.
My transmitter is Crystal Palace.
Cheers
Well to see if it's the box that's at fault have you tried it in the living room? You may also need an aerial upgrade if your area is supposedly not covered by Freeview.
