Freeview Problem
18 Oct 2002
In the air with the balls
I've got a Toshiba 32WLT58 that I bought in October last year. Recently when I switch on it comes up "No Signal". Sometimes I switch channels and it comes up but now it comes up permanently "No Signal".
If I switch to analogue it's fine but obviously can only receive the analogue channels. There's nothing wrong with the signal since the HTPC with my freeview PCI card receives the signals no problem. I'm thinking there's nothing wrong with the input since the analogue reception is fine.
So, I'm thinking there's a problem with the Freeview receiver on the TV - any ideas? I'm glad I bought from John Lewis with their five year guarantee.
Any thoughts?
Have you plugged your PC into the same physical wire/socket at the time as you have this problem?
If the answer is yes then try a full channel re-scan/new installation on the TV.
Failing that phone JL.
Yes, it's the same feed. All of a sudden it's working again but the re-scan sounds like a good idea :)
