- 7 Mar 2003
- Close to the Edge
Hi all. Apologies for the long post, I’m trying to provide as much info as possible. I’m after some troubleshooting advice, or maybe some experiential knowledge. In late October I bought an Asus TUF RTX 3080, and for good measure a Corsair HX1000 PSU. I fitted these into my existing system (replacing a RTX 3060). This system prior to the upgrade was solid as a rock for 2 years. Things appeared fine. Benchmarks were as expected, and it ran games well. On around 13th November I got a deadlock freeze in windows. This has only happened when idle. No black screen or bsod. Only thing I could do was a hard reset. There were no error logs anywhere. The only logs for the time was relating to my hard reset. There are no whea logger events or the like. This happened again 9 days later (around 60 hours plus of run time). I took the decision to return the PSU and replaced it with a 1000w Asus Rog thor psu. I also disconnected a mechanical hard drive. Things looked good until yesterday when it happened again twice within a few hours of each other. This is about 180 hours of problem free run time since the last freeze.
I ran memtest overnight error free. OCCT tests run error free. All temps reported as fine. Fans do not ramp up when the freeze occurs. I’m struggling to see how I can troubleshoot this, with errors taking anywhere from a couple of hours to almost 2 months to appear. I have played games for hours on end with no issue. Anyone seen the like of this, or could point me in the right direction?. Can a fault with a graphics card manifest like this?. Many thanks.
System - Windows 10 pro. Asus x-570f gaming motherboard. Ryzen 3900x cpu. Crucial ballistix 32 gb ram at 2666mhz.Crucial mx500 1TB system ssd plus Crucial 2TB ssd. Asus tuf 3080 GC and Asus Rog Thor 1000w psu.No overclocking.
. Do you have a spare SSD etc you could run a test OS on leaving your original one in tact?
