Got a freezer pro on its way should be here tommorow morning or monday,
the manual online says this
way that the fan blows the hot air to the back. Use
there a case fan to remove the hot air. In case you
are using our Silentium PC Case, the Freezer 64 Pro
should blow the hot air to the front since the cool air is
drawn in from the back.
The problem being that my socket 939 retention bracket on the mobo is
the other way round, You clip the heatsink on at the top and the bottom as opposed to sides,
So which way round do i mount it ?
Align the Freezer in a standard ATX case in such a
