Seconded. I've been running that combination 24/7 for four months without any problems.WJA96 said:Fits fine - excellent combination as it fires right across the PWM circuit.
MeatLoaf said:Well fitted the cooler ok but whe i switched ot back on i had a nightmare time as it keot going on off on off![]()
I thought the mobo had gone belly up![]()
MeatLoaf said:No i meant the PC going on off on off, the fan stayed off all the time.
WJA96 said:Ah! No, the PWM wouldn't be responsble for that! What was it in the end?
beachBOYken said:i just ordered the ds4 and artic freezer 7 , i got it with some artic silver 5 thermal compound how do i go about applying it?
beachBOYken said:do i need to wipe any old compound of the cooler as i heard some come with standard compound already applied?
cheers
