On closer inspection of my freezer 7 pro which arrived this morning I noticed one of the 4 supports (which hold the plastic push pins) is not quite square,i.e. if the plastic pins were removed and the bracket was placed on a flat surface 3 of the feet would sit flush , the 1 in question would be raised off the surface slightly.I have no problem fixing this ,
just wondered if it was part of the design so it fits easier ?
Thanks
tommysdad
Thanks
tommysdad
(Gigabyte P35 DQ6)
