Freezer 7, should I use AS5??
17 Nov 2003
Gateshead
I got me a freezer 7 for my 6300.
Should I use the supplied gunk on the cooler or should I clean it off and use some AS5?
TIA :)
My temps improved removing the stuff which came with it. Im using akasa thermalpaste still have yet to put my AS5 on lol.
The grease with the Arctic Freezer 7 is MX-1 which is just as good as AS5 in my experience. The problem with a new AF7 is that they put to much on. If you don't want to change it then I would scrape away a few mm all around the edge of the pre-applied grease and give it a good few twists when sitting it on the CPU.
cheers
