frost free freezers work like this.
1 moist air freezes behind the shroud
2 behind the shroud heats up every so often
3 causing the frosty stuff to melt and run out a small hole into a collection plate at the rear of the fridge above the compressor
4 the heat from the compressor heats the collection plate causing the water to evaporate.
5 your freezer stays frost free and never needs to be defrosted/scraped by you.
does the ice collect at the bottom of your fridge almost like a frozen waterfall? because that means the heating mechanism that defrosts your freezer is working but the water cant find a way out
if yes try
turning your freezer off and leaving it off for 12-24 hours so all the ice can melt , the tube the water runs down has probably frozen so the water cant escape.
if yes try
