Hi all... Many apologies for requesting help with my first post.
I've seen this issue a whole lot on the net but no real confirmed fixes. You see I'm having trouble with my PC freezing after a while. I know the following:
the less RAM I have installed the longer it runs before freezing
I have upgraded the PSU recently as I'd thought it was a power supply issue, however this does not seem to be the case.
I've had some luck removing the BIOS battery, this seems to allow me to run the computer but it will freeze if I try to load certain programs like "3Ds Max"
I feel quite sure that this must be a BIOS issue. I have installed the required drivers and tried updating them also...
My rig is as follows:
CPU : AMD Phenom 955 Black Edition
Motherboard : ASUS M4A785D-M Pro
PSU : Coolermaster GX Bronze 750W
RAM : Crucial Ballistix Tracer DDR 2 800MHz ( 4-4-4-12 2.0 )
GPU : XFX Radeon HD 5770
HDD(s) : Western Digital Caviar Green 500GB
Any help would be greatly appreciated!
