Freezing issue.
8 May 2011
Hi guys, looking for some help on an issue that has developed on my build (spec in the sig)
When loading into any game the Display unit turns to no signal and the fan on the graphics card switches back to default speed (i run it at 50% when in game, set in the catalyst control center.)
I've reinstalled and updated catalyst control , tried booting in safe default mode in BIOS and tried on numerous games.
All other lights and fans stay running on the PC i just dont have a display.
Any help would be great , cheers ?
Disconnect the drives, use a single RAM stick and then see if it displays the POST/BIOS screen.
You can also take the GFX card out and use the motherboards VGA output and see if you then get a display.
