I've got a problem with my pc and i need a bit of advice. Everytime i run an application such as a game that needs the pc to work, it freezes after a while. Normally it's after a couple of hours but the past couple of days it's been less than 30mins from when i start the app to it freezing.
I've tried running the app from the moment i boot up and i've tried running the app after leaving the pc idling for a few hours. It doesn't seem to make a difference.
I've been checking the temps as well, cpu stays at about 40c as does the mobo chip under load. The gfx card maxes out at about 85-90c under load.
I've had this problem for a while but it's got a lot worse over the past few days.
Heres the full specs of the pc:
Asus A8N-sli deluxe
AMD 4200+ dual core s939
1.5gb generic ram
XFX 6800GT
SB Audigy 1
Seagate Baracuda 200gb sata hd
samsung dvd-writer
All running off a Tagan 480 uo-1 psu
The majority of the components are getting up to 3 years old bar the cpu. Thats less than 6 months old
Any help would be greatly appreciated
Thanks in advance
Asus A8N-sli deluxe
1.5gb generic ram
XFX 6800GT
SB Audigy 1
samsung dvd-writer
Thanks in advance
The tagan psu should have enough juice to run my system but saying that, the problems did start soon after i'd put the 4200+ x2 in. There was a 3000+ winchester in there before.
I had to take the graphics card out to put the third stick of ram in at the weekend. I check everything once a month anyway.
