- 17 Apr 2009
- East Northants
I have recently (past few months) been experiencing freezing of my system. If it happens, it happens between 30seconds - 2minutes after i turn the computer on first thing of a day. It all boots up fine and will get into Windows OK, but sometimes i will click on Opera or another time i will be just browsing the web and it will completely lock up. Mouse won't move, Keyboard controller seems unresponsive as the caps lock light doesn't respond when i press the button.
I have to reboot the computer from the tower.
When i have a look in Event Viewer, i see a critical error, but it is only the following error:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2009-10-20T09:05:56.593217700Z" />
<EventRecordID>2155</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>Win7</Computer>
<Security UserID=/>
</System>
- <EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
indicating that i shutdown the computer incorrectly (i had to to restart it).
I thought that i only really noticed it on my Windows 7 RC install on one of my hard drives, and not on my Vista install on my other hard drive.
However, i have recently purchased a new hard drive and installed a different copy of Windows 7 and i has happened twice already in less than a week of having this new HDD and OS install.
Any ideas?
Cheers
Jack
- <System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
<Security UserID=/>
</System>
- <EventData>
</EventData>
</Event>
Any ideas?
Cheers
Jack
