Frequent Flyer.
8 Oct 2005
Midlands, UK
Hi,
as described i have superman flying in a circle using rubberbands and sellotape (spelling) on my controller. However, after about 20 mins the controller seems to turn itself off and its displays "please reconnect controller". I press the guide button and its ok for another 20 mins or so.
How do i stop my (wireless) controller shutting itselfdown after 20 mins ish?
Thanks.
Huh surely if your playing or it thinks its playing it shouldn't turn off? Unless it's because no other input change is made in 20 minutes. I have never seen an option to turn that on or off.
I had this while I had one of the buttons taped down to max out points on Tony Hawks. If you've got a play and charge kit, just plug the charge cable in and then the pad won't turn off.
Oh yer, i managed to get this achievement eventually. I was actually having a shower and realised it had unlocked. Told ya i was good. God bless electrical tape :)
But of course you're not bothered about the achievements? :p
