Hey guys, Just looking for some advice regarding my new Oc, my systems in the sig, i was running my e6600 at 3.2ghz no prob but yesterday i thought i would try for 3.6ghz for an extra boost, its currently running fine but not sure about these volts, there cpu=1.6 mch=1.7 ram=2.3 and my memory timings are 5-5-5-15 does this seem to be about right? i ran 3dmark and my score (11577) is about the same as the score i got when i was running at 3.2ghz? what i want to know is are the volts im running ok and should i be running different settings for the ram? is the ram settings keeping my score down? any help is appreciated........
Mine maxed out at about 3.4 with 1.45v and temps will hit around 65c. Without water or a very good clocker your probably gonna struggle to hit much over 3.4v
got the cpu volts back to 1.5 and have the NB running at 1.65 and everything seems stable enough over the last 3hours, everything is booting ok and temps under load are max 57 degrees on the core, so what i want to know is can i relax with these settings as they are? cheers.........
