Go for burritos instead. Below is a very simple recipe. There are a lot of words but not much work as the majority of it is done by just slow cooking the beef
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
This should be enough food to absolutely stuff 3 people.
1 medium beef brisket
1 packet wraps
beans (I like borlotti)
1 onion
2 cloves of garlic
2 tomatoes
fresh chillies
chilli powder
smoked paprika
brown sugar
salt
pepper
rice
sour cream
guacamole
cheese (cheddar works well)
Heat your oven to super low (80C).
Sprinkle chilli powder, smoked paprika, brown sugar, salt and pepper on the brisket.
Add the brisket to the oven. It will sit in there for 6 hours at least. Cover it lightly (not completely) with foil.
At the end of the 6 hours, take the brisket out and completely wrap it in foil.
Leave it somewhere to rest whilst you do the rest of the food prep.
Cook your rice.
Slice up your onions, dice the garlic and cut up the tomatoes.
Fry the onions until soft, throw in the garlic and fry for 1 minute. Add the tomatoes and lower heat to minimum. Now add the beans (washed). This will need to simmer for up to 10 minutes. Towards the end add 1/2-1 teaspoon of chilli powder, depending on how much heat you like.
Your rice should be done by this point. Drain it and leave it to dry out a bit.
Turn the heat off on the onions/beans.
Slice up your fresh chillies into super thin strips. These will be served as a garnish on the side.
Grate up your cheese.
Get your beef brisket and unwrap it. Place it in a baking tray and grab two forks. Use them both to 'tear' the meat apart. You should be able to easily tear it into shreds without much effort at all. If you find this too hard you can just 'dice' the meat really finely instead.
Now you're done with the cooking/prep.
Place the beef in a bowl, beans in a bowl, sour cream in a small bowl, guacamole in a small bowl, chillies in a small bowl and the cheese in another bowl. Place the wraps on a plate.
Another plate to each diners.
Eaters build their own burrito by taking a wrap, spreading some sour cream and guacamole on it. Then they add the beef, the rice and some of the fresh chillies. Finally, sprinkle some of the cheese on top and roll up the wrap.
