Fried My CPU ?
22 Jul 2006
1. Put together a new i7-920 D0 in an Asus P6TD using a Titan Fenrir, in a stock Antec 1200, fans all at medium.
2. Boots up fine, temperatures seem a little high at 34C. Run some benchmarks and get 100+ FPS for a while in Bad Company 2. Max temp is mid 50s.
3. OC it to 3.8Gig, boots at 40C, run some benchmarks and it peaks at 72C. Start running Prime95 and it shoots up to over 90C. Immediately close Prime95 and closedown PC.
4. Give it a while to cool down and reboot. Temp in all 4 cores stays around 40C.
5. Fault has developed that a minute after boot the multiplier cuts roughly in half, with the relevant reduction in CPU speed.
6. Close down and cool off the system. Take off the Fenrir and remove the CPU from the Motherboard.
The fault is that the Fenrir has retained a small amount of Arctic Cleaner in between the base heatsink and brass rods that run through it when I have cleaned it prior to installation. A small amount of fluid has run down in between the base of the heatsink and the top of the CPU mixing with the Antec Formula 5 thermal paste.
a) Clean off the CPU and the Fenrir. Reseat using Arctic Silver 5 (not important but being as detailed as poss).
b) Boot system and it detects the newly seated CPU as a new one; I select to set BIOS options to auto. BIOS resets to initial state except that instead of going to Auto Multiplier sets itself to 21. Thus, once booted, CPU is running at 2.8 Ghz instead of 2.66.
c) Temps look stable at low to mid 20sC across the 4 cores.
d) Under no load and at these lower temps, the multiplier stills cuts itself after running for a minute to 12 from 21, reducing the CPU speed from 2.8Ghz to 1.603Ghz.
Questions :
1) What is causing the multiplier to reduce itself ?
2) Is the CPU likely to blame and now 'fried' or faulty?
Cool, thanks again mate.
Thought I'd blown 200squid :)
Tricky to dry off those Fenrirs once having used the Arctic Cleaner fluids. Thought I'd dried it thoroughly and even had the hairdryer on it.
As an aside, while we are at the point, what 'lint free' cloths do people use with the cleaners to clean off old thermal paste ? Are any available from supermarket or chemists or anything similar ?
What you describe is not a problem, at least it shows you have the CPU running in a economic way with turbo enabled :)
I rarely see a 21 multiplier on mine last for long!
i just overclocked my 920 to 3.4ghz yesterday my temps are good so far, voltage on my bios was set way too high at stock settings was at 1.25v so i overclocked the cpu and undervolted it, i now idle at 37c ran prime95 for 4 hrs reached 55c max when i was at stock at those voltages i reached 70 lol everything is stable so far going to go to 4ghz soon when i got the time
______________________
Gigabyte X58 UD5
i7 920 3.4ghz going to 4
6GB Patriot Viper 1600mhz
XFX HD5970 BE
750w Be quiet dark power pro
Silverstone Raven RV01
