Friends PC keeps crashing
18 Oct 2017
Hi all hope this is in the right section.
Me and a friend were playing dayz the other day after about half an hour or so his PC crashed with a white screen.restarted and Within 30seconds of playing it crashed again but with a black screen. His HDD has been slow lately so he tried a fresh install with a ssd and the problem persisted. He was using a hd7950 I had one not being used so we tried swapping them out.
This seemed to do the trick he left his PC on to update while at work came home during his lunch break to find the PC crashed with a black screen.
Not sure of the PC spec
Gigabyte MB
AMD piledriver cpu
HD7950 GPU
I can get the spec if needed later.
The only software installed with the fresh o/s was Mb drivers ,steam ,dayz and AMD DRIVERS
Any idea where to start looking
I think the aio is a sealed unit. How would the fluid be checked? I'm assuming I can the pump rpm in the bios
It will have a PWN connector, if it's setup normally, he's like got it plugged into the CPU fan, in their you can see it's RPM. Or, if it's got a USB header, it's likely got it's own software.
By ear. Unscrew the radiator, hold it above the pump and tip it back and forth so you can hear the fluid sloshing around. Too much air is bad. Then hold the radiator below the pump and repeat - there should be no sloshing (the radiator should be full). You could also weigh the assembly, though I can't immediately find the weight.
Don't be fooled by them calling it a sealed unit. Fluid will very gradually leak, both through the tubing - on their website Corsair say their tubing is 'Low permeability for near-zero evaporation' (bolding mine) - and where the tubing joins the radiator and pump - it will gradually evaporate there too. If too much is gone then cooling
And by ear.
