Hi Guys!
I have just noticed that my Frio Advanced is very loud! The spec's say it goes up to 44db, which makes a fair bit of noise in my opinion.
The cooler is brilliant, but would like to change the fans for something a bit quieter.
Problem being that the fans are 13cm according to thermaltake's website:
Has anyone got one of these coolers? Any fans you could recommend as replacements please? Would a 12cm fan be able to fit?
Thanks
Thanks
