Morning all,
Thought I would create a thread showing my move from my prodigy to the 250D, with the hope it helping anyone out there considering the case. I was in two minds as to whether the thread belonged in the project section, but didn't feel it worthy, so apologies mods if I have got it wrong!
Anyway back on track.... no change of components listed in my sig and was a straight swap, though I did add the following lights to make it look all pretty inside http://www.overclockers.co.uk/showproduct.php?prodid=CM-045-LP&groupid=701&catid=1428&subcat=1430
Here is a couple of pics comparing the size of the 2 cases.
In the end I had to remove the optical drive bay to make way for the H60 cooler as i found this to be the best position for minimal cables blocking the view inside of the case from the windowed top. Also I was originally worried whether the HIS IceQ 7950 would fit in this case and whilst it was a struggle I got there in the end.
And finally, a couple of images showing the completed build with light fitted
Hope you all enjoyed the thread - any questions I will do my best to answer
