I should say, the only reason I bought an IPS panel the first time round was my (extremely sad) tendency to be a bit of a technology snob
I don't do photography work - colour accuracy isn't really criticially important.
The second benefit, wide viewing angles, I'm not sure about. I sit directly in front of mine, and generally don't have more than one person viewing it at a time.
Obviously, the bigger you go, the more you're looking at certain parts of the screen at an angle (the edges). I'm wondering if, with say a 27" TN panel, you'd notice the edges greying out, or looking off-colour?
60% of my time spent in front of my monitor is web browsing, 30% gaming, 10% watching video of some sort.
So, for the sake of getting a bigger screen (big IPS are $$$), will the jump from IPS to TN be one I won't notice, or a huge mistake?
I don't do photography work - colour accuracy isn't really criticially important.The second benefit, wide viewing angles, I'm not sure about. I sit directly in front of mine, and generally don't have more than one person viewing it at a time.
It's great, but it's small, and the OSD buttons no longer work (in fact I had to open 'er up and take out the circuit board, because the buttons had started to operate by themselves
