- 15 Jul 2009
Ok, so after the palava about my poor little overheating E2160 a couple of weeks ago, I now have new ram and am getting on with some serious first time testing! Just wanted to post results so far and have some of you more experienced folk offer suggestions.
Intel Core 2 Duo E2160 @ 1.8GHz
Foxconn G33/31 motherboard (max 1333FSB/800DDR2)
Kingston HyperX 2x2Gb DDR8500+ @ 5-6-6-15 (motherboard can't register more than 15 tRAS)
Started at stock voltages for CPU and ram, dropped the ram divider to 667 and pushed up to 2.6GHz (1152FSB / 480x2 ram), past that it came up unstable.
Tried pushing up memory voltage to 2.2 as rated with no effect, dropped the FSB back down and bumped the ram divider to synchronous to test the same ram speed at lower CPU load. Passed 490MHz at 1.8v, got up to 548MHz at 2.0v, now pressing on at 2.2v to find it's maximum.
That much seems obvious, so next is dropping the divider back to 5:3 and pushing on with the CPU clocking by upping the Vcore, knowing the ram is well within it's limitations. That's where the questions start, since bumping the Vcore is where things get theoretically dicey. Obviously at first you bump FSB until it comes up unstable and then bump the Vcore by one grade to see if it becomes stable again.
Am I missing anything obvious in my proceedure?
How much should I expect to get out of the increased core voltage?
Is the return going to be a diminishing one? ( I assume so)
What is the maximum reasonable Vcore bump? (I've read 20% but wanted to ask again anyway for opinions)
Cheers in advance for any thoughts...
Scottage
Scottage
