Hi Folks,
Need a little bit of guidance (again). Currently I have a 2-3 year old PC. It’s a single core running a AMD 4000+ san diego.
I’d like to put in a dual core, obviously involving a new motherboard and CPUs. What I would like to know is (having never built a dual core PC) how much room with the dual core take up? Do I need a new case to fit it all in? Will be PSU be ok for all my components?
Here is what I currently have
Thermaltake VA7000BWA Shark Aluminium Full Tower
DFI LanParty UT NF4 Ultra-D (Socket 939) PCI-Express Motherboard
Samsung SpinPoint P SP2504C 250GB SATA-II
Gigabyte G-Power Pro (Socket A/754/939/478/775) Cooler
Hiper HPU-4K580-MK Type R 580W Modular ATX2.2 PSU
2 x Corsair 1GB DDR XMS3200C2PT Platinum CAS2
Creative Sound Blaster X-Fi Xtreme Music
Gainward ATI Radeon HD 4850 512MB GDDR3 TV-OutDual DVIHDMI (PCI-Express)
AMD Athlon 64 4000+ San Diego (Socket 939)
Ideally I would like to just take the cpu and mobo out and not have to splash out on a new case but if I need to then so be it. I need a new PSU anyway as this one can’t be converted to work in the states – so replacing that right now won’t be a problem, but obviously the new one will have to work in the states.
Also if you guys could recommend specific motherboards, CPUs and fans that would be a big help. I'd be using the PC for gaming. I'm not sure of what the current prices are for these components so I don't know what kind of price range I could put on it - as what I suggest might buy me a hamster running in it's wheel for me fan!
Thanks in advance
Dave
Thanks in advance
Dave
