From the top !
2 Jul 2007
SABERTOOTH Z77
hi...
ive got 3770k @ 3.7 at stock (mobo default settings) it runs at 1.088 under load with VID @ 1.1359 temps 55, what the best way to overclock it?....ive had it up 4.5 @ 1.220v temp mid high 70's but it was on fixed voltage id like to move to offset for overclocking but really want to know the best way of going about it...
thanks for reading :)
from what i've seen in other similar threads 80 degress at 100% usage is fine, so work up to that and see how far you can take it.
might help to post up rest of your spec, cooling, ram, mobo etc.
also, a few threads around for the 3570K, have a look at them and see what you can pick up.
