Front Audio Not Working
6 May 2009
Hi guys , ive plugged the hd audio wire from the front panel off my haf 922 into the F_Audio slot on my gigabyte UD5 motherboard but when i plug something in the front panel there seems to be no sound. any ideas?
Thanks
Have you used the correct plug, on my 932 its got an ac97 audio connector and an HD audio connector , dont know if this is the same with the 922 though.
Dave
Think you can use either but you have to state weather its using the HD Audio one or AC97 one, my board is set at HD Audio by default though, mines set in Bios but just read through a UD5 manual, dunno if its the same as yours as theres several and it says you need to set if its HD Audio or AC97 connection being used somewhere via software?
Dave.
Am not sure tbh, just seems to be extra wires connected on the HD Audio plug. Am sure theres more to it than that though lol.
Dave
