Front Bay Kit?
26 Jun 2009
Uckfield
Right im after front fan bay kit.... just to hold a fan of my choice.
I have seen the Scythe but I want to use another fan with lower noise levels + high cfm.
Any help would be appreciated.
I have searched but nothing found.
Id suggest the scythe kama bay, then simply add the fan of your choice, the supplied fan isnt that great as far as airflow goes. I replaced it with a sharkoon silent eagle in mine.
I'm not aware of any others but you could always get the Kama & swap out the fan for whichever 120mm fan you desire.
Edit: beat me to it...
Thanks.
I have thought about this but £17 seems a bit steep to just go and replace it with a £10 fan.
