Front Bumper
27 Mar 2004
England
My front bumper has strangely dropped, it's dropped an inch on the passenger side and you can see the little catches off the arch. I've tried lifting it up and pushing in but it drops back down.
How does it tighten up?
Will get some pics if you want.
They not bolted on mate?
Should be push pin clips or screws holding the liner up to the metal panel, take them out and check out the bumper fixings which should be under it.
