Front case fans, PWM or not?
19 Nov 2015
Glasgow Area
Hi all,
I'm going to be buying an NZXT s340 very soon. It has space for 2 fans at the front. I have a couple of 120mm fans lying around ready to go, 2 are PWM and 1 is just 3 pin. . My question is, should these fans be PWM or just 3 pin? I'm not really bothered by noise and would take Cooling over slight noise any day as I game with headphones on.
Also, any particular headers I should plug them into? Im thinking of plugging the rear fan (included with the case) into the 2nd CPU fan hdr as it will be directly behind my CPU air cooler so matching the speed of that will be beneficial to vent out CPU waste air. But I am not familiar with the different Motherboard, or SYS fan headers. And how they behave R.E case fans.
Thanks.
