I have a Thermaltake Armor +MX and the front fan makes a grinding noise when I start the pc from cold.
It does this for about 5 minutes then it just stops and is then very quiet.
I know I can replace the fan but I have not been able to remove the hard drive cage, yes I have unscrewed it but I think something is wrong with mine it just doesn't budge.
I have also done a volt mod to quieten down the fan, I can't remember how I did it I just followed a guide but it involved moving the pins around.
Anyone got any advice as to how I can stop this grinding noise? Would spraying WD40 on the fan help?
Thanks
Thanks
