Hey guys,
i have 2 front fans (120mm) and the bottom one had started making a flicking noise so i assume the bearings are on their way out.
This is an ocuk build from 3ish years ago (maybe one or 2 more, time flies!)
so i assume i would want to replace both at the same time?
Any suggestions?
Good air flow and low noise, i don't need any fancy lights.
Ocuk built it so i don't know how long the cables need to be (are they all standard?)
I'll also need to find where they plug in, but i'm sure i'll manage!
cheers
Any suggestions?
cheers
