Front Mounting An AIO
17 Feb 2009
Had my Kraken X53 a few months now and initial installation was easy ( using a pull configuration that meant having the fans on the left of the rad )
I was bored so thought i'd set up a push configuration (so the fans are between the RAD and the case ) And also so I could see my RGB fans from the front.
It was a nightmare keeping the two fans and screws in place before attaching and screwing the rad to it.
I had to use some removable adhesive to keep it in place whilst attaching the rad and after that it was fairly straightforward with some trial and error moving the rad around to line up with the holes.
Am I right in saying some cases have a detachable front panel to make it easier ?
You see the front removable panel in this video ( at 2:50 ) which I Don't have unfortunately...
Thankfully I managed to fit it in the end and it looks really impressive...
your meshify c front panel is removable. As is all front panels. Some front panels have pins you need to squeeze and push each pins through but most you just simply pull and it pops off as is the case with yours :)
Yeah the front panel can come off as shown in this picture...
But im talking about the rails that the fans/aio attaches to which I referred to in that video
you should be able to pull the front bezel off. That will uncover the thumb screws to be able to pull the rad/fan bracket off :)
Edit: this cannot be done on your case so it would seem. the bezel is fixed and only the front mesh can come off. such a shame as that would make installation a lot easier.
Good idea with this is to secure the fans to the case using the normal short screws then position the radiator and replace the short screws with the long ones, one by one.
