Front or top radiator mounting?
16 Apr 2010
Hi All,
Getting a new case, Cooler Master H500 and was wondering whether I should mount the radiator with its two fans as the top of the case as exhaust or at the front which I've seen others do. It seems to me that the two 200mm fans at the front of the case should be used as intake rather than strapping a radiator to them but perhaps other peeps can advice the pros and cons?
Cheers
Daz
