Hi,
I've just joined this forum for some good advice---
I wish to build a PC or two and sort out one or two that need some attention but I'm a newbie at this so go ez....
I've already got some bits n bats on the way to help get me started and familiarising myself with certain aspects of the MOBO / case etc.....
On one of the PC's I've got is a 4U Case. On the front is the front panel connections for the PC to boot the PC with some buttons on to reset with an activity light or two etc....-that's not my concern here.
Looking into the case is a long white cable (could be shorter IMO) which connects to 2 USB ports and the controls of the front panel connector with a snake cable for all the associated features the front panel provides.
My question is do front panel connections usually come with a PC case as standard whenever someone buys a new PC case? - It seems like they may do but I don't know which is why I ask - apologies if this is too basic for you guys.....
And are there many manufacturers that make these to be sold to fit into cases that are going to be modded?-
EG. I may remove mine and get a shorter cable for example....
I've looked in the shop here and I've found one made by NZXT - but none other yet.
Good advice here please then I'll move on to the next thing I need help on and maybe I'll not be a newb on this for too long.....and have more control over my systems....Thanks
....tomorrow the anti static mat etc arrive so I'll whoop the HD's out within the cage plus the DVD drives so I can see the cables in question properly - It looks like there are pull out connectors for the front panel - I'm so green at this I don't know 100% what I'm dealing with but I will.....
