Front Panel Connector Help
14 Aug 2010
UK
Hi,
I have an Asus P5Q and I'm a bit confused about the front panel connectors to the mobo. I have 4 connectors named
Power SW (2pin)
Reset SW (2pin)
Power LED (3pin)
HDD LED (2pin)
My mobo is arranged as follows:
Now the pins @ 13 seems to be randomly arranged. Does it matter how/where I plug them in? Vertically or horizontally?
Cheers,
The pins at 13 are indeed the ones you want.
The manual you can download in PDF form will clearly show exactly what pins are for what.
http://www.asus.com/Motherboards/Intel_Socket_775/P5Q/#download
If you get cant work out which way around the ± go, then,
For the Power and Reset SW it doesnt matter, their job is to only briefly short the two pins.
If the HDD LED and Power LED dont illuminate, just swap the pins/connectors 180 degrees around.
Thanks for the help. Got it sorted now :)
