- 18 Oct 2002
- Kuala Lumpur, Malaysia
As per this thread : http://forums.overclockers.co.uk/showthread.php?t=18062897
I put this machine together (has been a while) and everything is working ... apart from I can't figure out how to connect the power/reset switch etc. connector from the case on the motherboard - the pinouts don't make any sense to me.
I've switched it on and installed OS etc. by shorting the pins using a screwdriver - not a very long term solution though
Anyone using the same combination? Last time I built a machine all the connector cables for the front panel were seperate
