- 18 Nov 2012
Hi all
Not sure if this is the correct section to post this in, but I'm sure many of you will have the answer anyway.
I am doing my first PC build, using a Corsair C70 case and a Gigabyte D3h motherboard.
When I come to connect the various small front panel wires of the case to the relevant connectors on the mobo, the + and - are clearly marked on the motherboard's individual pins, and where the + and - wires are separate that's easy, so far so good.
But where the C70's connector wire is a two pin plug (eg,. Power switch) I cannot tell which way around this is supposed to go onto the mobo because the + and - wires are not marked on the wires themselves or it's connector (there is a small arrow next to one of the connectors but not sure what this means it is + or -).
Does it matter which way around these go? Or is there a standard way of telling? Does the arrow usually mean it is the positive?
Help greatly appreciated, thanks in advance
Rick.
Rick.
