- 25 Nov 2011
- The KOP
Hello guys is they anything you can do here? I had my GPU installed into the bottom slot it was ok with the stock cooler n because it had little gap under.
But because the Corsair HG10 is just solid base I can not get it to fit into the slot.
This is how I had it with stock cooler has you can see the GPU fitted
But now I have had to move the GPU one slot up this is working perfectly fine, my only worry I now have is I want to use another HG10 on the top GPU but I have a feeling that the tube from the H75 will be pushing down onto the other GPU?
