Front panel LED's not lighting up
23 Oct 2004
HW,Bucks
Having a problem with an Akasa Eclipse 62 . None of the front LED's are lighting up, its more of an annoyance then anything , but i would like to get it sorted.
I've connected everything in the right place on my motherboard (DFI Infinity 975X/G) and connected the front panel connectors like the manual says , but still nothing works.
Anyone got any suggestions?
Also, seeing as there isnt much of a manual for the akasa eclipse , has anyone got an online manual for it that would have a more detailed picture of the connectors etc.
The LED connections are +ve and -ve, they won't work if they are the wrong way around.
Check'em out!
Btw, you won't cause any damage if they are the wrong way around, they just won't work.
Michael
had the same problem before, just turn the connecters the other way round. I thought it was Writing up but obviously not.
